Finally lowered the car, installed new bushings, balljoints..... LS1 Camaro front brakes.....17" Torq-Thrust II's. 3" in the front, 2" in the rear and new Bilstiens all around. 😀
[/img]
Did Robert set you up on those?
UpstateNYer said:Finally lowered the car, installed new bushings, balljoints..... LS1 Camaro front brakes.....17" Torq-Thrust II's. 3" in the front, 2" in the rear and new Bilstiens all around. 😀
[/img]
jonnyslick said:UpstateNYer said:Finally lowered the car, installed new bushings, balljoints..... LS1 Camaro front brakes.....17" Torq-Thrust II's. 3" in the front, 2" in the rear and new Bilstiens all around. 😀
[/img]
Oh man that looks amazing. What springs did you use there?
Tony_SS said:On the Monte I'm not running any since I have tubular lower ca's. On the Malibu I did not trim them, no bottoming out on them so far.
The LS1 brake setup is the best bang for the buck IMO. Any plans for rear discs?
I got your PM but I'll answer you here... My tie rods on the Monte are level, I just replaced them all this weekend. I haven't had an alignment yet, but that shouldn't change their angle.
You're still using the g-body spindles right?
UpstateNYer said:Tony_SS said:On the Monte I'm not running any since I have tubular lower ca's. On the Malibu I did not trim them, no bottoming out on them so far.
Yeah, stock spindles but the tie rods still do angle up. I will try to take a picture. As for the bumpstops, they are about 3/8-1/2" away from the frame but that could be quiet a bit of upward travel out at the wheel.
As for rear discs, maybe in the future I have to get rid of this 305 first.
