85 El Camino -- Electrical weirdness!
K-Toe
39
13
62
As mentioned in my previous posts, I pulled the 350 and 700R4 and cleaned and painted the engine bay. I modified the engine wiring as required with the Sniper EFI and Hyperspark installation. Other than temporarily unclipping the lighting wiring to remove the fenderwells for ease of cleaning and painting, I did nothing to the stock lighting wiring harness. This is where the weirdness begins!!
My park lights, emergency flashers and turn signals work, but my headlights do not. My windshield wiper also works, but they won't turn off. I double checked to ensure that the headlights were grounded. Other than that, I'm clueless as to how to rectify these two problems.
Any suggestions?
Any suggestions?
Where is your main ground on your setup?
The engine is grounded in two ways. It is grounded to the frame and the body.
And you have inspected both of those by pulling on the connections, on each side correct?
Yes! Plus...both of the grouping straps are new.
Alright. Make sure the fuses are ok, and if that is good, try grounding the headlights somewhere else.
g0thiac:
Okay...I will do that and get back to you! Appreciate the quick responses!!
Reactions: g0thiac
