86 cutlass Rear end swap
kolesar
5
Im trying to put a posi into an 86 cutlass for my friend,
I got it out of an s10 and got it all shimmed up and in perfect. but then the axles didn't fit.
I can't seem to find axles gears for a posi or axles with the heavier spline that will fit
so I was wondering if a rear end from a 85 camaro would fit without much customization.
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
is that carrier 7 5/8? I'm thinking it must be and it's a 28 spline if your axles don't fit
kolesar
5
yup its 7 5/8 so I need to find 28 spline axles that will fit the carrier,
I found 28 spline axles but they a couple inches longer thats why I was wondering if the Camaro rear end would fit.
or if you know any cars that would have proper length axles with 28 splines
I couldnt find any other g body cars at my local junkyard and all the ten bolts i ripped apart where 7 1/2 carriers
kolesar
5
Im not sure if the GN axel will work because its a 8.5 in.
Isnt the cutlass a 7.5?
85GPLef41
2,210
159
Colorado
still the same length though..
