I've been asked by some of you to post some pix of a project I've been working on so here they are with a little bit of narrative. Here's what's been done so far.
1) left rear trunk floor patched
2) underside of car sandblasted from rear to firewall (everything underneath *)
3) underside primed
4) underside painted
5) underside undercoated (only the body sheetmetal. I'm leaving the frame painted. I've seen some unwanted things, like rust, happen when you undercoat the frame.)
6) all new NiCopp lines installed. This included switching the evap line from the right to the left side and the fuel line from the left to the right and deleting one line. 84' GP has only 3 lines whereas the 86' had 4 lines. 305 has it's fuel line on the right side. This also included all the brake lines from the proportioning valve to the rear brake cylinders plus a new rear brake hose.
7) new proportioning valve
8) new master cylinder
9) new shocks in the back
10) sandblasted and painted the gas tank
11) made a new parking brake cable guide (attached to the drivers side rear floor) because old one had rusted away
What's left to do is install the left rear reinforcement and the frame rail end pieces and then reinstall the gas tank and rear bumper and the new parking brake cables. For the gas tank I have a new sending unit since an '84 has only 2 outlets and an '86 has 3. Installing the reinforcement is the next thing I will be doing. And because somebody is going to ask about those ramps...I built them myself at a cost of about $120 for the materials.
* I did not sandblast the driveshaft or the brace below the transmission yoke since they will be coming off during the engine swap and that's the best time to do that. Also, the trans crossmember is different for the 305 than the 231 so I didn't sandblast that either as I will be using the one from the '84 and that's when I will sandblast and paint that too. Thanks for following.
3) underside primed
