My previous project was a 2004 Grand Prix GT2. it is currenly being demodded so it can be sold. I've had my share of fun building it with a topswap, xp cam, headers, nitrous, and applicable supporting mods. I didn't want to mess with fwd anymore, it was fun for a reliable driver.
This picture was in the 2011 GTPworld.net Calendar
I also have a 2005 Grand Prix Base model that I daily drive. No current plans for modding that besides maybe some audio and visuals at a later point in time.
On saturday I picked up my 86 Monte Carlo SS rolling chassis, with T-tops! I have plans to put in a 5.3/ 4L80E combo to get it running this year. This winter, I will most likely add a turbo or two into the mix and see what it can do. Here's what it looked like when the old owner mocked up an LQ4.
As of now, this is what I'm thinking for the MCSS. If anyone has any better/ less expensive alternatives, or I'm missing anything, please let me know.
Rolling Chassis: 1986 Monte Carlo SS- T-top
Engine: 5.3L Vortec V8 (LM7)
Cam: 02-04 LS6 cam PN 12565308
Heads: Stock Truck
Valve Springs: LS6 PN 12499224
Pushrods: Stock
Intake Manifold: Stock Truck
Throttle Body: Stock Truck
Intake: Ebay 5.3cold air
Alternator: Stock Silverado
PCM: Silverado
Tuner: HPTuners
Radiator: Stock 86 MCSS
Cooling Fans: GM3800
Motor Mounts: 1” Setback Trans Dapt 4516
Headers: Stock Truck
Catback: Custom 3”
Fuel Tank/ Cell: Summit Racing SUM-293215-S (26 gal, 20x18x10in, -8an fittings)
Fuel Cell mount: SUM-291215S-99
Fuel Pump: Mallory 5250A (Ethanol/Alcohol only or 5250 Gasoline only)
Fuel Filter: Jegs 5 long 555-150005 (Gas/Alcohol)
Fuel Line: Braided Stainless
Fuel Injectors: Stock Silverado
Fuel Rail: Stock Silverado
Transmission: 4L80E
Transmission Crossmember: Gforce #35XM
Rear End: Stock Monte Carlo SS
Driveshaft: 52.5” Factory Length
Driveshaft loop: BMR DSL003H
Wiring Harness: Silverado
Battery: Optima Red Top
Battery Box: Summit SUM-890102 (Trunk Mounted)
Battery Kill Switch
A/C: None, firewall blocked
Nitrous: Zex wet kit w/ Window switch
Trunk Firewall Block: Cut all extra stock metal/ pop rivet thin sheet of metal over it
Hood: VFNFiberglass 4” cowl pin on if no stock found
Rollcage:
Suspension:
Gas Pedal: Silverado (Electic tps?)
Heads: Stock Truck
Pushrods: Stock
PCM: Silverado
Tuner: HPTuners
Catback: Custom 3”
Transmission: 4L80E
Battery Kill Switch
Rollcage:
Suspension:
