I just picked up a 87 Cutlass Salon today and it has a stock 307 in it. The previous owner had an upper radiator hose blow off the waterneck and he said it got up to 285 before he shut the car off. Now the car wont start.
1) What could cause the hose to just blow off, hose and clamp are fine, no longer has any antifreeze in the radiator.
2) Its getting spark, fuel and air, checked compression on 5 of the cylinders, ranged from 85-100 so while the compression is low it doesn't appear to have a blown headgasket or melted a piston. what would be the next spot to look? The engine cranks over normally, just no start.
Not looking for it to run like a new car just need to be able to move it around for now.
