87 Olds 307 radiator hose clearance
boyd4762
14
Need help with my radiator hose on my 87' Olds Cutlass Supreme, it's too close to my alternator!!! :?:
Oldsmoletick
1,581
10
38
cny
Easy fix if you have an electric fan.......get an upper hose for a 73 olds cutlass with a 350, much nicer routing away from the alternator, don't know if it would work with a stock fan though.
The upper hose is nowhere near the alt, but may interfere with a stock fan.
dan2286
2,233
4
Cleveland, Ohio
Isn't there supposed to be something on the fan shroud that kinda holds back the rad hose?
kustomkyle
646
47
There is a plastic zip-tie/clip that holds it back, but it is more towards the center of the fan shroud. There should be a few inches between the alternator and the radiator hose. Was there any modifications done to the car or is the hose a generic piece, etc.?
boyd4762
14
yeah, it is suppose to be a radiator shroud but i'm missing that piece. hopefully i'll find one in the salvage yard.
boyd4762
14
Great idea, but what type of vehicle did the electric fan come off of :?: you don't have any issues with overheating?
Oldsmoletick
1,581
10
38
cny
It is a dual fan from an 03 or 04 olds auroa V8, no problems overheating, the car will idle in traffic in 90+ degree weather at 180 degrees. I need to post better pics of it for someone else on here, I forgot to take them this morning though :blam: .
boyd4762
14
have any new and better pics yet?
Oldsmoletick
1,581
10
38
cny
Here are the pics of the fan, like I said did require quite a bit of trimming, upper and low radiator hoses and transmission lines, but as you can see it takes up the whole radiator. I haven't "finished" it off yet, plan on filling in the spots I had to cut so it looks a little nicer and come up with a better way to route the wires. For mounting, very simple, two 90 degree tabs bolt to the stock locations on the upper radiator top plate, and drilled two holes in the fan shroud. For the lower portion, I drilled one hole through the center of the shroud and used one of the transmission cooler straps to hold it. It's not the nicest looking thing yet, but it works excellent, and provides plenty of air movement.
thumbnail pics
