88 Cutlass Rear End Swap????
The 7.625" spider gears are bigger than 7.5" that came factory. I blew up my spider gears in my 7.5". I am going with Moser 28 spline axles and the Torsen posi. A girdle cover won't hurt either.
Agreed thats also the rt I am taking.
Anybody ever thought about taking an 8.5 out of a late model b-body and having the tubes shortened or swapped out with 7.5s, if they will fit in the 8.5 housing? Would probably be a lot cheaper and easier to find in a yard.
If your a good welder, very possible. You fabricate nearly any rear to work. My welding sucks. A 68-72 A body and later Mustang can work with conversion control arms.
The problem with shortening axle tubes on GM cars is the axle spline is cold rolled so you can't cut and re spline the axle to get the correct length like you can with a machined ford axle. Also the tubes on a 7.5 is a smaller diameter than the tubes on an 8.5
Was online looking and came across this. Hope this helps.
The stock 78-88 A/G body rearend housing (housing flange to housing flange) is 52.125". Here is a list of other common rearend dimensions:
Body Style Housing Width
64-67 Chevelle 54.250"
68-72 Chevelle 55.250"
67-69 Camaro 54.250"
62-67 Chevy II 52.125"
70-81 Camaro 55.375"
82-92 Camaro 55.750"
93-up Camaro 59.250"
68-76 Nova 54.250"
78-88 A/G Body 52.125"
Information from Chevy High Performance Magazine 3/2001
I wasn't aware of the difference in tubes. You still could shorten a b body 8.5, then use aftermarket axles, which would still probably come in well under the 7-800 for a g-body 8.5.
