88 monte ss fuel pump
bluebronco69
26
where is the fuel pump on an 88 monte carlo ss? on the frame someplace or under the hood?
thanks
85montess
173
46
CT
If im not mistaken, it should be in the same place as mine, under the hood. it should be a silver cannister with metal hoses. i think......
bluebronco69
26
i dont know what i was typing i meant fuel filter lol,
thanks
85montess
173
46
CT
that should be attached to the carb. with what should be steel braided wire. it goes from the carb to the cylinder chamber.
85montess
173
46
CT
the factory hose should be black rubber. steel braided wire is an upgrade or a step above if you will. it is stronger, doesnt corrode or weaken over time, and looks wayyy better. i is basically a whole bunch of steel fibers braided together, much like a rope is, except with steel.
JESSE
366
7
GULFPORT,MS
fuel pump
i don't know what you guy's are talking about!!! if your car has a quad 4 bbl carb the filter is in the carb it's behind the big nut were the fuel line goes to the carb... :?
85montess
173
46
CT
yeah thats what i said. it is attached to the carb
85_SS
683
Ontario, Canada
The factory fuel line from the pump to the carb was a one piece steel line. No rubber or braided lines.
The nuts on the line often sieze to the tube itself causing the tube to be destroyed, then replaced with rubber or braided line.
