Hi,
I just purchased a 88 ss with a 290hp 350 sb. Was running fine no smoke, when I get it home after 150 mile drive I noticed it smells pretty bad and smoking. Not blowing clouds or anything but steady smoke. Sometimes smokes more other times barely seems to smoke. But always had a really nasty smell from exhaust.
Pulled plugs and they were all oily.. Ran compression and results were all 130-135psi.
Motor has under 2000 miles on it with all paper work and looks like it does.
Any ideas where to begin? I've been told it could be valve seals, valve seal guides, piston rings.
Should I do leak down test? Are these compression numbers ok?
Any help is greatly appreciated. Thank you
