I have quite a lot of 1/4" line leftover. Do you happen to know what thread the fitting is on the caliper?I have Wilwood's , since it is a fixed caliper you just run hard lines to the calipers.
I mounted my T block in a Stockish location and bent hard lines close to the caliper mounts to tabs welded on the housing. I finished with 10" wilwood braided lines. I need to relocate the drivers side line more to the rear of the housing due to some contact with my exhaust tube. But otherwise it works perfectly.
I gotta question for you, how are you going to mount the pigtail springs on those spring perches?. 🤔
Quickperformance built the axle housing for me. They or Ballistic Fabrication have all kinds of goodies for driveline fabrication.where did you get those spring perches, I was looking for the type you have but I could only find the ones that fit a 5" spring. I ended up using the spring perches I cut off the 8.2 to sit them on the middle of the tube
Do yourself a favor and have a short flex hose where the line meets the caliper,that way you can remove it and not fight the hard line.if i remember ill snap a pic of mine Sunday.
