9 inch first pattern
thanks for the reply
thanks for the reply turna. been looking at about a million of those gear patterns. i'll be trying some of them to get the best pattern.
Ring gear needs to go towards the pinion, loosen the rh lock 1/2 turn tighten the lh lock a half turn and re pattern
thanks for the reply. that adjustment will affect my backlash which is at .008 right now. i will be using that adjustment and pinion spacer adjustments to try to get it in spec. i started with .020 pinion shim and .008 bl as a starting point. pontiacgp's video looks to be one of the best ways of adjustments i have seen so far. i've only done about 3 diff. builds in my lifetime so far and i would like to get this one right. i'm getting a little too old to be going back in there and redoing everything again. thanks again
