Do you plan on using the computer from the donar car? If not it really won't be that bad of a sawp and it's been done by many.. if you don't use the computer make sure you get a lock up wiring set up for the transmission...Good luck with the swap and keep us posted 8)oldspower said:how hard is it to swap these into my 81 cutlass compared to a regular 350?? any info would help. is it even possible to swap in this transmission?
