98~05 Blazer brake upgrade! DONE!
You used adapters for the lines?
Do you reflare the lines? that has 1/2-20 threads on both ports
I am going to try the old Plymouth Fury brake booster next.
Ports are the same tread bore is 1.031
This use to be a pretty popular swap many moons ago on just about everything
4
Not sure if this was mentioned in this thread but if you use the 2wd, 4 door Blazer front hoses. You will not need an adapter from the hardline to the caliper hose.
