_____-to DualJet carb adapter
RustRocket
351
86
Las Vegas, Nevada
Hi all, I'm looking for some help here. I know it says its for a Holley but I'm wondering if this adapter:http://www.ebay.com/itm/Moroso-6495...ley-/161671964434?hash=item25a4666712&vxp=mtr
will work for my car so I can use a Rochester 2g or 2-Jet in place of my DualJet. Mine crapped out on me and I have a few hookups on some free 2GC's and 2-Jet's that I can get. Do you all think this could work on my car? Its the 231, and I'm in desperate need for a carb. Thank You very much in advance
Since the adapter is for a Holley 2 barrel to a Holley 4 barrel it will not work since a Rochester 2 barrel has a different bolt pattern than a Holley 2 barrel and a Dualjet if I remember correctly has a unique bolt pattern that it shares with no other carburetor, plus I believe the Dualjet throttle bores are spread farther apart than traditional 2 barrel carbs causing a big mismatch.
I doubt you will find an adapter for your application but you could make one out or plastic phenolic canvas sheet it is very easy to work with similar to wood but very tough. http://www.ebay.com/itm/5-Canvas-Ph...Cut-to-Size-/271760079215?hash=item3f4629b96f
