I am looking at one of those Mopar A-833 overdrive transmissions that GM used in the '80's. They called it the NP440 or MY6 and it was in various Chevy vehicles like Blazers and Sierras. I know the main case, tail housing and input shaft were changed so they could bolt up to a special Chevy dual pattern bell housing. But is it true the hole in the bell housing is a bit larger than the standard GM housings because the input gear cover is larger than what GM usually used? And the dual bolt pattern housing- was that a Chevy only item? Was it also Chevy/BOP? So to use it behind a Pontiac 400 I would need to enlarge the input gear cover hole? And what about the bolt pattern? Is there enough meat on a BOP bell housing to just make new holes? I would not want to use a Chevy-to-BOP adapter. Anyone try this?
