I had one bolt stick on my lower control arms on my 442 when I rebuilt everything.
Tried soaking it for days, tried the air hammer... it was fused in there.
No torch at home, so I ended up grinding off the head of the bolt as well as the chunk of threads poking through the other side.
I then used my dremel to dig in and grind more out, until I was finally able to get it free.
What a pain in the *ss.
Put some grease on the new bolt when you put it back together, so in case you have to take it apart again, you don't run into the same problem.
