A/C Dilemma
LT1B-Body
191
90
20
Maricopa Arizona
So, still working on the 78' Malibu. The car had A/C from factory, and the owner would like it to have A/C again, not an unreasonable request in AZ. I was thinking of going with a Vintage Air style kit and just spend the extra dough. But, apparently, nobody makes any kits for any Malibus/ Elkys after 72'. So, I figured I'd try and piece an A/C system together from factory parts. Unfortunately, my ac box is missing a good chunk of fiberglass that I can't repair (don't have the missing chunk).
The solution here of course is to find a new old air box from a different car, but in AZ there's no guarantee I can find one in any better condition than mine. I'd also like to stick the engine and trans in and I'm not sure if I should until I get the ac box in.
I'm not quite sure what to do at the moment.
Posting pictures of what you need would help. I have a pretty complete AC box out of a 5th Gen El Camino. Other significant issue is I live in Hawaii. Let me know if you're interested.
I'll take some pics when I get home later. I pretty much just need the firewall A/C box. All the rest of the parts I can get.
If shipping isn't absurd I might be interested.
Question, will having the engine in the car stop me from being able to put the ac box in?
Not if it is a small block. Probably have to pull the exhaust manifold/headers on that side, maybe the valve cover.
Reactions: LT1B-Body
I pulled the ac box out of a monte ss in a junkyard without pulling the engine or the valve cover, or exhaust manifold. It actually went pretty easy, took less than an hour from start to finish. Biggest issue I had was getting all of the rusted bolts out for the inner wheel well in the front where the battery tray was. If I had my tools from home it would have been even easier.
Remove the wheel and the fender liner. That should give you some good access.
