I've recently had my new a/c installed and charged up. I have noticed that when in a/c mode, the air comes in from the defrost vents and lower vent(s) only, and not from the forward vents.
Do these control units go bad over time?
I did manage to get underneath the dash and connected my vacuum/ bleeder pump to one the two vacuum servos that open and close the flap, or blend door. I started the car and turned the a/c on, and kept the vacuum pump on one of the servos. It did divert the air to the forward vents.
Now I'm assuming it might be the control unit itself, being that it's vacuum controlled or activated.
Has anyone had to replace the dash control in order to have the vents working properly, or is it more likely to be the vacuum line going to it?
Also, are these units used in later GM cars? Perhaps I can find a later unit that's in "fresher" condition.
