A/c with Ls Swap
F
ForeverFella
7
Chattanooga Tennessee
#1
What are yall doing to run a/c with yall swaps??
motorheadmike
motorheadmike
3,362
6,284
Ottawa, Ontario Canada
#2
Using stock stuff? Hard work. And lots of it... or throw money at it to use aftermarket parts.
motorheadmike
motorheadmike
3,362
6,284
#4
F
ForeverFella
7
#5
Then get out your thinking cap, cutting tools, and welder... or your wallet.
The wallet is wide open... I already have new compressor, accumulator, heater core, o rings just trying to see what problems people are running into
8
81cutlass
1,536
2,014
Western MN
#6
Stock truck pump fits. Just have to run F body block mounts instead of the SBC frame mounts with adapter plates.
Just can't put the fuel lines through the frame in that spot and might need to get some truck AC hoses and have a local shop crimp on some R12 style fittings you can buy off 4seasons ac parts. Rock auto and summit stock almost all their parts.
https://gbodyforum.com/threads/ac-notch-or-relocation.60298/
superbon54
superbon54
149
283
#7
I’m interested in this topic too. I’m rebuilding my heater box soon and will be running an LS, so I’d like to buy parts and do the work once.
8
81cutlass
1,536
2,014
Western MN
#8
motorheadmike
motorheadmike
3,362
6,284
#9
Holley has lots of solutions.
O
ostrich
Aug 27, 2012
98
59
Ontario, Canada
#10
Working on the swap right now. Have most of it done. Ended up with a bracket (can get the company if needed, using truck accessories) to move the AC up from the bottom. Used an R4 compressor from an 89 Blazer, 82-92 Camaro AC hard lines & condenser. 85SS stock heater box, evap, drier etc. All the Camaro stuff connects with just a little bending.
Had to go high with my AC because of the flipped exhaust manifolds for the turbo.
Thread starter Similar threads Forum Replies Date
B G-Body LS Swap 20
Winkernod G-Body LS Swap 27
E G-Body LS Swap 13
Markt361 G-Body LS Swap 0
motorheadmike G-Body LS Swap 27
Similar threads
