When you think you are ready to put the side cover back on check a few things. This can be the hardest part of the operation. All shifter hubs and paddles MUST be in neutral to go back together easily. Reverse shifter has a spring loaded detent ball under it. Make sure either a shifter arm or a couple of washers are installed under the outside bolt to hold the reverse shifter in tight. Otherwise the spring pulls the arm in just enough so if the arm moves the ball can go BOING! After I found the errant ball and put washers under the bolt I also noticed the two shifter paddles were loose. They had slipped out from their detents in the side cover and would not engage the shifter hubs. All these things must be in place properly or you will cuss up a storm trying to get the paddles to slide into the hubs correctly. When the paddles are in their proper place in the neutral position they will be held tight and not move. Then you can insert them into the hubs and engage the reverse shifter with the idler gear. You will know it is right when the side cover easily fits flush against the main case. It will all go together smoothly only if things are in their proper place. Don't force anything or you may break something and then you will want to hang yourself. Put a couple of bolts in the cover and see if it shifts properly. NOTE: if the reverse shaft in not held tightly with either a shifter arm or washers under the bolt then the reverse shifter will interfere with the other gears inside and you will think it is broken. If all gears shift right then go ahead and put the rest of the bolts in and tighten to specs. Probably best to dry test installing it a few times and make mistakes when it is easy to correct them . I use some Ultra Black on all gaskets so fumbling with this while sealer is getting on everything is a huge pain. Even though I have rebuilt plenty of Saginaws it has been long enough since my last time that I am forgetting stuff I should know.
