Hi, hope everyone is well. I am working on getting my 84 monte ss back on the road and I have run into a little snag. The short version is that I have no power running to the ignition switch on top the steering column, I have horn and lights (mostly, a couple of side markers are not working and turn signals are not working with one of the indicators stuck on). I pulled the main plug on the firewall in the engine bay and I have 2 hot blade terminals, I am assuming one powers lights/horn and the other is supposed to provide power to the ignition switch. Cleaned everything and reassembled, no dice. If I gently pull up on the wiring harness of the main plug in the engine bay I get enough of a connection to turn on the test light when probing the red wires going into the ignition switch with the key in the OFF position, as soon as I turn the key to the ON position I lose the connection. This is repeatable, I am guessing the blade terminal that powers the ignition switch is not making good contact (I am not sure which is which). I have a few thoughts on how to fix this, but I wanted to get some second opinions.
1. Bend the hot blade terminals on the plug side to try and get a better connection
2. Shim the sockets for the hot blade terminals on the receptacle side
3. Tin the hot blade terminals on the plug side so that they are large enough to hopefully make a good connection
Maybe none of these are a good idea and there is a proper way to fix this that I am unaware of...any input would be appreciated.
Thanks
Thanks
