I'm not sure if anyone is really looking at this, but I will post again.
Went out and got the Malibu started yesterday. I found out that the car had been sitting since 2003. It had been started one time since. It has really went down over the years. A lot of surface rust and few rust holes here and there. There is a dent in the top, trunk and hood. Tires are rotted bad. The windsheild had broke at some point. and there is a leak in the front. The carpet was damp and molded in a couple spots. The dash was cracked and gaped badly. Steering wheel melted and sticky.
Other than all of this after cleaning a swarm of dirt dobbers nests, priming the card and jumping the battery it fired on the first try. It took a bit to pull up the fuel, but it ran. I drove it out the road and back. It was about two quarts low on trans fluid and it still locked in gear and shifted perfectly.
I think he told me that the engine was rebuilt and bored 40 over on the 3.8. It originally had a lock up TH350 which was replaced with a non-lockup. I picked up a few things for it yesterday. A wire brush, some primer and fabric/vinyl die. (Don't think the dye will work well. But worth a try before I rip stuff out.)
New goals.
New tires on the Centerline Rims that I have. Upping to 15's.
New windsheild.
New steering wheel.
Clean inside and out.
Remove and repair and visible rust.
possible dye the carpet and seats.Maybe paint some trim.
License, Insure, and Drive It...
New goals.
New windsheild.
New steering wheel.
