Hello Guys, i´m new here.
I come from Germany and drive a 1985 Cutlass 442.
I hope i get some techtips from you.
Even when i start to accelerate, (OD / D / 2 / 1) everything is fine, but after pressing the pedal between 2.000 and 3.000 rpm it´s feel there is no sparks. The car don't move forward because acceleration is lost. When i get away from the pedal everything is fine.
I recognize the same problem when i drive uphill
When i do this in NEUTRAL, there is no problem to increase the rpm over 2.000 or 3.000.
That problem is only in Drivemode.
After checking Check Engine Soon, i got the error code 21 (TPS). I replaced a new and the problem is still there.
I think the problem is located at the Distributor, maybe the Spakmodule or the Vacuum is damaged.
I had replaced the ignition coil too.
Hope to get some help from you.
Thank you for your time.
Greeting Maurice Malone
