Factory heat onlyIs this a factory heat only car or did someone remove the ac?
Since you nothing factory to work with your best bet might be a complete system like Vintage Air for Gbody or a similar system depending on your budget.Factory heat only
Sure. All you need is a parts car with everything. The hardest part is the dash and underdash parts. The underhood parts are very easy to add, but a parts car is still desirable for all the brackets and stuff. You will probably want brand new compressor, evaporator, condenser, accumulator, and hoses.can I add factory ac
