Alternator I bought was too small. 3.8 v6
Olgambler84
Dec 26, 2018
68
65
Swapping out my alternator , old one was failing. The one I bought from autozone was not wide enough, do I buy one for a v8 or what?
6,836
6,748
do you have a 3.8 chevy engine (distributor in back) or a 3.8 BUICK engine (distributor in front)?
Gwarren79
711
1,549
Safford, AZ
Since one of your posts says you have a Cutlass, I looked up a 1983 with a 3.8 and its lists a 5.5" case AND a 5 15/16" case .
And this is at Autozone.
9,198
15,457
For the alternator used in our cars the cases are the from '78-'87/'88. They are clocked based on the engine family they are used on. I've used "incorrect" clocked alternators on different engines. If it's the wrong size them it looks more like an error on Autozone's catalog.
Olgambler84
Dec 26, 2018
68
65
Went to San Pablo automotive supply, and they informed me that I needed the higher voltage alt with the bigger casing. Went in with no problem
RegalBegal
705
747
Goldsboro, NC
You need a 15SI alternator. You could also swap in a CS144 with 12-6 case clocking (say from a 1992 Eldorado) which is the same size
