OK, I'm looking at an 83' Pontiac manual, V-8 motor, and the 2 red wires, 1 from the "batt" terminal and 1 from terminal "2", both go to a fusible link that is bolted to the starter same place as the battery cable. All a fusible link is, is a short piece of smaller gauge wire than the line it is in, that acts as a fuse when the line gets shorted out, and saves the wiring downstream. Any auto parts store has them and you size it to the wiring you are repairing, 8 gauge, 10gauge, etc. But from the picture you have I think all 3 went to the alternater. One or maybe both reds must go down to the starter and the brown to the firewall. Can you follow those red wires and see where they lead?
