I may be nearing the point where I'm going to have to replace the battery in the Olds, currently have a Die Hard that was in there when I bought it and it has served me well considering the way I've abused it. But it's getting to the point where if I don't start the car after a couple weeks it needs a little help. Case in point, tried to start it yesterday after sitting in "Hell's Kitchen" for the past 1.5 weeks (100-degree index, high humidity days & nights) and most of summer, got a decent initial crank, then the rrrr, rrr, rr, r. Before buying I'm still going to take it to have load & hold tests on it to back up what I'm thinking / doing at home. The only drain I have is from the headunit (presets, clock and the like), not getting any crazy draw on the battery that I can read when off. Charging system is ok, getting +14V when running, and right around 14V when fully warm and running, battery was low yesterday, about 11.8V. Hand-held mutlimeters and aux. gauge are pretty much reading the same, even in-dash gauge is close. Alternator is a 78A unit.
I am wondering what should I choose. Because of the electrical loads I have on the car currently (basic sounds - amp, two 10s, changer, aux gauges), future plans (improved alarm, perhaps bigger amp) and my infrequent driving was thinking of getting a Red Top Optima, but also thinking of an Interstate, believe the Mega-Tron?. So did a search here, other boards, net in general and most are staying away from the Optimas; some bashes were so bad I thought they were talking about Exide / GNB batteries. The problem is no one was really clear as to why they felt the Optima was so bad, only saying the quality's gone down hill the past few years. I was leaning towards the Red Top, due to the AGM, dual-post design, warranty but now am not sure. Had an Interstate in the '81 years ago and that thing didn't die, was like it refused to let go, granted it only had to turn over a 260 but still.
What do you guys think?
Sorry for the long-winded lead-up but wanted to give as much info as possible - thanks.
