Minion1186 said:thats for the replies,Did you guys have to drill holes in the frame to bolt up the x member?That's my main concern,I don't want to drill extra holes in my frame.
84cutspreme said:Not sure of jegster but the g-force did not require any holes to be drilled, however 79-83 years require you to buy an additional frame extension piece with the g-force crossmember that costs another $30 due to some frame difference.
Nevertheless no drilling holes is required with any of the crossmembers to my knowledge and no floorpan fab either.
84cutspreme said:Not sure of jegster but the g-force did not require any holes to be drilled, however 79-83 years require you to buy an additional frame extension piece with the g-force crossmember that costs another $30 due to some frame difference. Nevertheless no drilling holes is required with any of the crossmembers to my knowledge and no floorpan fab either.
Qdub24 said:I've got an 83 and I didn't need that frame extension. Mine bolted right up in place of the Jegster x-member.
