I can verify that the f-body Cargo Coils will fit with the f-body isolator. I've had them on my car. Yup, CC652 is the number. I don't know if they drop over the stock g-body springs or not. My old springs were sagging badly and I had alot of *&%# (junk in the trunk) parts in the back afterwards.
Considering they take about 30 minutes to swap out, I'd install them and let them settle for about a month. Then if you want more drop, cut 1/4 - 1/2 coil at a time. It's easier to take more off but if you drop it too much, it's time to buy new ones and start over.
Unbolt the lower shocks. Jack up the rear of your car with both rear tires off the ground about 6". Use jackstands on the frame. Twist/tilt the rear up or down and the rear springs will practically fall out. Almost scary!
