If it was water only it probably popped out the freeze plug or plugs. It happened to me long ago on a straight 6 camaro I had. Thankfully the block didn't crack. I hope yours didn't either.
freeze plugs or frost plugs are actually an incorrect term though very commonly used, including by myself. they are core plugs, the holes that these plugs fit into are used to remove the sand used in the casting process. luckily they have a tendency to pop or get pushed out when the coolant freezes.The water thats coming out is crystal clear...ive dealt with head gaskets..highly doubt its that...thats why theres freeze plugs right..to prevent any of that from happening...plus no white smoke neither
Thanx for the info...its a 3.8 v6 1983 cutlassfreeze plugs or frost plugs are actually an incorrect term though very commonly used, including by myself. they are core plugs, the holes that these plugs fit into are used to remove the sand used in the casting process. luckily they have a tendency to pop or get pushed out when the coolant freezes.
i can't identify the engine in the picture, but its always best to start at the top and work your way down. is the intake gasket leaking or anything that threads into the intake leaking. intake gaskets can leak internally or externally. same with head gaskets, its nice to hear that no white smoke is coming from the tail pipe when running. some cylinder heads have core plugs in them also. you may need to use a mirror or if you know someone with an inspection camera to borrow. plumbers and mechanics use these to see in places you normally can't view.
Im in seattle...we barely hava a winter..Why were you running it with water in the radiator? Seems that a $20 worth of antifreeze during the dead
of winter would have prevented all this from happening. Freeze plugs are not fun or easy to get to in the back of the motor.
