Any Buick 455 guys?
That is a desirable block & heads to have - the heads are 67-69 but some found there way on 70's. The rocker arms are also desirable. You will probably find a 1/2 oil pick up and gallery which needs to be updated to 5/8 if not already done. Had a rare 70 GS 4 SPD A/C car that a guy offered me stupid money for.
Reactions: -83MONTESS-
I personally would hang on to it, you never know what you will build later on when the Monte is done and around here I never see Buick engines for sale. The old big BOP's are hard to come by.
I have always loved 68-72 Buick cars, mostly the A bodies. I will probably hold onto it either for a rainy day or in case I get in a pinch and need some money, parts, or labor.
Reactions: Garrett1982
Hell, if i had the dough, I'd buy it off ya right now. But this is just about the most desirable Buick V8, aside from the nailhead engines.
If you plan to sell it, the guys who are really interested in it, will want to inspect the block bare. I would do what you can to prevent it from rusting, and clean it up ready to inspect. Or if you want to make it pretty, you could always take a ton of pictures, and seal it up/paint it. The stuff buyers would want to know is basically what a machine shop would check when they are selecting a good core. Bores out of round? main bores in spec? crank reusable? etc etc... among other things like core shift of the lifters.
Look for cracks at the base of where the rockers mount, the early heads were prone to cracking there, especially if they are 430 heads. (Yours are 1970 455 heads).
There are basically 2 animals of heads. The open chambers (bad) and the closed chambers (good). You have closed chambers. They are otherwise more or less identical, with the 1970 having the highest flow, largely due to the valve size. The early years also had the Stage1 valve option, which you do not, identifiable by the "heart shaped" combustion chamber.
The later blocks had slightly better casting processes and slightly bigger oiling passages, but with the heads, and the block you have, its a desirable combination for someone looking for cores. As they sit, you maybe able to part them out for around $600. I have bought complete running engines from $200 to $500. If you got it crack tested by a shop, it would bump the value up slightly, but more importantly people will feel more reassured when buying. ie: more customers.
http://www.buickperformanceclub.com/455Blocknmbrs.htm
http://www.buickperformanceclub.com/455hdcompare.htm
Final comment, its just an engine, so yea you need to take special care to make sure you build it within the recommended specs, but no need to get all aboard the stigma train of how these engines are so special that you cant build them unless you have some kind of divine blessing BS.
Reactions: RegalBegal
I had the pleasure of having one.
I should probably update this. I bought a 91 C1500 SCSB 5 speed truck with a blown up 305 for $400. Extremely clean and straight just needs an engine. I have a Buick friend that had a brand new mild 355 sitting on an engine stand. So long story short we made a trade. He has a 455 for his Regal and I have a brand new 355 for my new daily driver.
I had nothing but tire kickers with the 455. Everyone wanted casting numbers and date codes but never bought it. Oh well it worked out better for me anyway.
Cool
