Autometer gauges
Mx372
Jul 30, 2012
53
I have a 83 elcamino and the speedo died. Solution ? an autometer tach and apeedo!
Pretty creative there, what size are those gauges? I thought about doing that to my Monte this weekend when I installed a tach, decided against it and mounted to the steering column.
they are 3 and 3/8 inch. To be honest it was super easy to do this. all i did was ground the existing hole to the right size and removed what ever needed to get the gauges to sit in right. and i still have the printed circuit working the oem stuff.
Nice, so did the gauges run into the circuit board behind the speedo or tach?
Sent from my iPad using Tapatalk HD
I also wanna know if your center gauges work. I am doing the same thing with the Autometer speedo and tach but they hit the circuit board and the inside of the shadow box so I had to gut the box and cut out the back. I'm gonna lay a ABS sheet on the cluster and redrill the speedo and tach and mount a fuel level gauge inbetween the two. Since the dummy lights won't be use I'll make a panel to go over them and drill thee 2 1/16" holes for the water, volt and oil pressure gauges.
