That's a bummer, I wouldn't mind a few extra gallons for my Regal when I eventually switch over to FI..This tank fits El Caminos only!
You gotta keep in mind the El Camino had more room under the rear of the bed as the wagon has the spare tire well that takes up alot of the space back between the rear rails. Eliminate the spare tire well & that would make space but that would then add extra work of sealing off the big hole left & where to store the spare & jack. Sad thing is no one is paying attention to you wagon owners who want to use in tank pumps for fuel injection or LS conversions.Ah...So Elco’s only. Bummer. I know there are some similarities between the Elcos and wagons, but Elcos have a 10” longer wheelbase. Thanks for the info.
pontiacgp,,,it's my understanding that they use the B-body sender, and you can get the sender with a pump for a throttle body, or, the sender with a pump for the LT1/TPI swap. ...The thread is: EFI conversion,,, it was posted on 2-25-2012,,, the poster was: RoyalKnight82,,, and CCC's post is #2
