B-Body thread
Buford T. JuSStice
341
192
Sup fellas. Just wanted to talk about my B-Body a bit since I haven't done much lately with the G-Body and this last week was interesting to say the least.
A little background: aside from my G-Body wagon, I also own another G-Body 4Dr Regal which I inherited, an F-Body which is awaiting time and money for a new engine and transmission, and two B-Body Chevrolets. The older one is an '87 Caprice 9C1 with a good engine and transmission, but a totally destroyed body and frame (thanks to years of ice melt on the roads in New England) and my daily driver is a '95 Caprice 9C1.
The '95 came from the factory with an LT1. About 5 years ago I upgraded (or so I thought) the ignition system with what is called an "LTCC" system which converts the infamous Opti-Spark into a coil-over-plug ignition system. It was supposed to be more reliable, easier to maintain, and a great conversation piece. Only one of those things proved to be true. Over the past 5 years I've had nothing but trouble with the damn thing. At first it would blow out ignition fuses on the highway, meaning the car would suddenly die and be without any power. After a while I decided to up the fuse to 25A rather than 20A, and this seemed to do the trick... for a while at least.
One night out of the blue the ignition switch on top of the column decided to blow out, again... cutting the vehicle's ignition dead cold while driving and left the passenger compartment filled with the foul stench of burnt electronics and smoke. Took the dashboard apart, dropped the steering column (much more involved than it is on our G-Bodies because the entire lower dash has to come off) and replaced the ignition switch. Then it fried one of the coils and the car ran on 7 cylinders until I could get a replacement from the autoparts store... and after that it gained an appetite for the cheap autopart store coils.
Let's just put it this way... after 5 years of this, it blew out 4 ignition switches, 3 coils, an untold number of fuses, and all the while it skipped, sputtered, and made me dislike driving that car, but I never did anymore than fix the problems as they came up because I could never figure out what was causing them other than the system itself. I can take apart the dashboard, drop the column, and replace an ignition switch on that car in under an hour with the proper tools. I can piece together the brackets for the stupid thing BLINDFOLDED.
Well, last week I finally had it. Drove to work last Tuesday and it got there just fine, no problem. Lunchtime came about and I went out to my car to go pick up some grub and the car wouldn't start. The starter kept turning over the engine, but no spark... plenty of gasoline smell but no spark. Hopped a ride with a friend to go get lunch instead, and after we ate I came back to it and tried again... started up after a bit so I figured maybe it was nothing. Went out to the car later that day to go home... no start again. After trying for a bit I finally got it to chooch over, and it got all of 100 feet before the ignition cut out and died. I was done. That was it. No more.
So I left the car there, got a ride home with a friend, and borrowed a family member's car to go to work (didn't wanna drive the wagon to work since it's got a few bugs to work out). When I got home I bought a new ignition coil, ignition module, the brackets and heat sinks, new wires and connectors. Stayed after work on Saturday and just pounded it out in 3-4 hours with the most time spent on fishing the ignition wires through the accessory bracket on the passenger side.
Car started right up, and you know what? I will never ever ever so long as I live, bad mouth Opti-Spark ever again. The power comes on smoothly, it doesn't sputter, it doesn't miss, and I already know that it isn't going to die on me randomly, and it isn't going to blow fuses, fry my ignition switch or anything like that. Opti-Spark has two enemies. Large puddles, and leaky water pumps. I can drive around puddles, and I can make sure my water pump isn't leaking every time I do an oil change.
The moral of the story is this though: If it ain't broke, don't fix it! Don't go and upgrade something just because they promise you it'll make your old tech more reliable and easier to maintain because it's a damn lie!
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Here's one of the very few times I'll recommend an LS.
Here's my B
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,510
4,906
Rolla, MO
COUGH
BBODYFORUM.COM
COUGH
(I'm gonna be a jerk and do this whenever a B-body topic comes up just so y'all are prepared)
Ribbedroof
4,904
7,013
Wellston, OK
The ORIGINAL Optispark on my 92 Vette was still going strong at 124K, I had opened it up at 118 and everything looked good, so i put it back together and ran it.
Buford T. JuSStice
341
192
Yeah, my LT1 Caprice has 210K on it and as far as I know, this is the original Opti as well. Of course, it got to skip out on maybe... I dunno... 30-40k? Still not bad though. Still gonna change it when I get the chance. No reason not to at this point since literally everything else in the ignition system is brand new already and it's got at least 150k on it.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,510
4,906
Rolla, MO
That link goes to a home improvement site.
fixed. I have no idea how that happened. I made bloody sure it was right before I hit POST.... :mad::ROFLMAO:
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Now it goes to PornHub????
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,510
4,906
Rolla, MO
