Fabrication is nearly done on the bottom frame. One more visit to my buddy with the welder (and more beer) should finish this phase.
A couple of do-overs: On each side, one of the donor supports got off on a tangent. It's visible in the upper left of the photo. These will have to be ground free and reconfigured. The shiny strip in the lower left was transplanted from the upper frame and is replacing a badly rusted piece found on the donor bottom. This is a weight-bearing part of the seat that needed a little extra support.
Still needed is bracing between the old frame and new in front to support the lucky back seat passengers. Before getting too busy with the upper, I'll be fitting 3-point seat belts in back. Surely some foam will need to be shaped to clear the retractor which will be floor mounted where the old lap-belt retractor is now.
