back yard built 383 stroker
soloone87
177
53
39
hollywood,fl
]figured id go ahead and toss up my build in the section, started out finding a pretty decent 305 monte carlo base model in homestead for 1200 that wouldn't start. after i got it home i shimmed the started bolts and it cranked right over when i tried to burn out to see if would leave 2 lines the car didn't have enough power to break the tires loose :rofl: so i instantly thought. 350 swap is needed.
i got a pretty cheap l31 motor (free from a family member) that had stock 906 vortec heads on it
its dirty its ugly its got a blown headgasket
one of the 906's where cracked so there goes a cheap head to build from.
I started this build backasswards i bought a 383 kit then a cam and then heads lol
the kit included all this crap in the picture
the cam kit came with a complete valve train kit
then i bought a cheapy set of bare aluminum 2.02/1.60 2oocc runners and 64 cc chambers
im also doing a big shot of spray on this block,
3 washers under each starter bolt got this 305 started
383 stroker kit from (if you couldn't guess) scat
motor on the stand pre-tear down
the two bolt in the corner that i started this build out with
my little work area
degreasser sprayed on
pure filth
AFTER an hour with the wire wheel and more purple power applied
i dropped this motor off to the R.A.C.E. performance in Davie ,fl a few days ago and im itching to get it back and start dropping that scat kit and all the other goodies into it
.520/.540 lift 288/318 dur 113 seperation
8inch
forged probe flat tops
i beam rods
retainers
timing gear
scat
2.02/1.6
1.6
proheader heads 64cc chamber 200cc runners
heads
close up of the chamebers
Wow talk about wish list lol... like a kid in a candy store!
Can't wait to see it in the car.
Reactions: soloone87
Those seats are in boss mode. Are they just re-covers or where did you find those at? They would really set off the suede ceiling in my 88 Cutlass
when i bought the car the interior was already done i think they got the seats reupholstered here some more interior pics i think im going to rip it all out and recolor the panels only because they are looking straight out of the junk yard fresh lol
