17x9 with 5inch backspace in the rear would work with drum or disc brakes. 17x8 would work with a 4 or 4.5 backspace for the front. If your using the 17x9 I would go with a something bigger tire wise for the rear like 275/40/17 unless you want to run the same size tire front and back. Ive used 17x9.5 with 5inch backspace on my el camino and Malibu and a friend's regal with no issues.
I am running 17x9.5 rears with 5" BS on my SS with 285/40's. She is close but clears the frame, since I lowered her 2" the tires will actually rub the wheel well lip if you go through a big dip in the road fast and the rear springs compress quickly.
Good to know! Got 5.125BS on my 9.5s but will just run 275s on mine. The measurements looked good but until you actually get them on the car and drive it . . .
Thanks. I wish I would have done my frame notch first then ordered my wheels with another 1/2" BS so it would clear the outer wheel well lip with no clearance issues.
