i bought it as a short block assembly they are 10.2to 1 keith black domes454cutlass said:454cutty said:o any sry should have posted some pics of my project![]()
what pistons did you choose
cool man mines a .40 over 454Ringers said:Sweet! You're a few miles away, I'm in Seattle! You are totally correct on the how deep you go. The olds motors are tough to go hard, unless you really get to know Joe. And empty your wallet then. The BBC's we run , we go deep on. But we're going deep into the inches too. 565, 588, 632 and minimum you're spending 30K, to go fast reliably. Good luck on your plate issue. I think we have a buddy that lives out there that could hook you up. I gotta look him up tho-Make sure he's still alive. Us old guys expire all the time!! Cheers-Matt
Rocket said:This might not be the best help but I put a motor plate in my car this summer but i'm running Olds' and switched to a manual box from Flaming River
u r prolly right but my car isnt hookin up at all right now with the 7.5 3.73 gear rear end and street tiresBar50 said:The deal with a motor plate is the frame is not going to flex around the motor area do to the cradle or what mustang guys call the K-frame. G-body cars do twist tweak beyond that quite a bit. This can, with a stout motor and sticky tires cause the transmission case to break, being the weakest link (think thin cast aluminum) right around the bell housing. New or solid body mounts and braces help. Roll bar or cage will solve it.
10.2 454 will have the 'umph' to break stuff if you hook it up.
Hey, some of us had to learn the hard way...
Minion1186 said:Have any pics of the other side of the motor plate? Specifically of how you have it bolted to the frame? thanksRocket said:This might not be the best help but I put a motor plate in my car this summer but i'm running Olds' and switched to a manual box from Flaming River
