I did the blazer front brake swap with slotted and drilled rotors on my Malibu and I want to upgrade the brake booster and master cylinder. I’ve read the best swap is the bbody 1990 caprice combo. I’m also planning to do a rear Camaro disc brake swap on the rear
10.75 is the biggest or correct diaphram size right?
When doing the swap are the brake lines the same on the original and bbody master cylinder ? For some reason I thought I read somewhere that you need to switch the brake line order going into the master cylinder ?
