The rims alone on the pictured T-type are probably $4000.
If you are short on cash to import Blazer spindles, consider cultivating a relationship with a machine shop. You could machine the discs off of a pair of stock G-body brake rotors, leaving the hubs with a surface for slip-on rotors. You would also need to machine your stock spindles to create a surface to bolt on the adapter plates for the caliper abutments. Do I have plans? No. But you could do some research and figure it out. Post details as you find them.
