Black box mounted to valve cover?
Just mak sure you got the needed pics, get the right forms & get a classic or antique plate. No need for a sniffer or visual inspection (I need to take my own advice for my car.)
No I don't have any part numbers for the EGR solenoid. I believe it's something you would have to acquire via someone parting out an 81-83 car with a 307.
Yes there should be an ISS ( idle speed solenoid ) on your carb that should have a dark green wire going to it. It also acts as a mounting point for your throttle return spring.
If you got an air cleaner from an 86 442 you'll have to drill a hole to fit the TVS.
Thanks! Do you have any idea what the gizmo that controlled the egr looks like or a part number?
Not easy to find them, they get tossed and are not reproduced and NOS doesn't exist anymore.
I have an NOS one if you're interested in it, probably the last one in existence...
Sure! How much would you want for it? You wouldn't happen to have the air cleaner TVS also? Well, let me see what comes on the dual snorkel air cleaner once it arrives.
Yes I have that too used $10, $75 for the NOS solenoid
Properly done stock set up would probably run better than any so called 'self learning' EFI system and be way more reliable.
