I have crushed glass and 40:60 aluminum oxide. I might carefully try the crushed glass on the thermostat and aluminum throttle return cable.
I tried that years ago and it still turned yellow from the heat. I use VHT aluminum header paint.I plan on spraying high temp clear after blasting it.
