I have my El Camino apart replacing the stock single piston brakes with the Blazer dual piston upgrade. My brake pads did NOT come with a hardware kit. I purchased a kit from AutoZone yesterday; it has only small clips labeled "L" & "R" for the ends of the brake pads. There is no metal clip to use for attaching the piston to the inboard pad. Nor is there any type of anti rattle clip?
Using the supplied small clips the pad fits tight into the the caliper pad holder. Is this all I need? is the tightness ok?
