Jim,
As I was checking online for the torque specs, I noticed that Autozone had the caliper torque @ 38 ft lbs. It just seemed a bit low.
Yes, they are the 12mm bolts. Well, I guess 85 ft lbs is it.
Thank you sir.
The 38 ft/lb spec is for the 4WD Blazer. The bolts are much smaller.
Also, I just looked this up this earlier this weekend as my son and I are in the process of putting C5 brakes on Blazer spindles. When I saw the bolts that came with the caliper adapter brackets it was pretty obvious that the torque was well over 40 ft/lbs.
