BUILD THREAD Blazer front disks & Camaro rear disk install
abbey castro
1,091
1,369
Harker Hts TX
Finished conversion of front disks to 1999 Blazer with spindles and dual piston calipers and 2002 rear Camaro setup. Really easy conversion just very time consuming and heavy parts to remove and install. I also had to touch up the other parts with plenty of soap and water and touch up paint.
What size rims on the rear?
Would a smaller rim clear?
Did you take any install process pics for the rear?
I can stick my hand between the caliper and the rim. I think that a 16 might work. Best way is to try one! I have attcahed some more install pis plus the e-brake set up using the factory cable barcket modofied to fit the Camaro cables. If you want to see them off-forum let me know. Its just pics with no notes
