Blazer spindles and UMI control arms
scoti
1,972
3,386
Texas
The UMI stuff is a direct replacement as well as the S10 spindles. UMI has specific arms for stock height ball joints or 1/2in. You obviously are totally out of whack in what you have done.
Or.... there could be a simple explanation.
Rt Jam
592
583
Ontario Canada
The upper arm does not limit the steering angle.
Out of whack, exactly Castro. That is the reason of the thread.
UMI can only blame the spindles since they are not a stock part.
403Olds
532
421
South Central Ohio
I looked at mine yesterday, it must be somthing with the lower control arms, my stock ones with the 1/2" taller balljoints, still hit the steering stops.
5,697
12,185
You have to grind on the spindle. They won’t turn as far as stock, but they will turn far enough. Or shorten up the tie rod tube.
Or adapt and overcome. My head is spinning from reading this.
bruisedbanana79
264
753
Haven’t driven it yet but from garage turning I gained a few degrees. Took a 3/16” plate to make a 1.25”OD washer and then took two 2.5” OD washers with a 1” ID to go over the nub on the control arm. Also prevented me from having to drill and tap my spindles. IMG_4118.jpeg
