hello,
Ending my project ls swap 83 cutlass. In the build I did the rear disc brake conversion, and the disc to disc proportion valve, new master cylinder w/ reservoir , and new brake lines.
I'm by myself majority of the time so I purchased the harbor fright vacuum bleeding. The bleeding went successful UNTIL I started the car. My brake pedal goes all the way to the floor and I have no brakes. No leaks that I can see. So I re-bleed the brakes. With the car off brake pedal seems normal again until I start the car. I've since purchase a new booster valve. Also I hear a lot of air when pressing the brake pedal. I'll try the old school conventional way of bleeding (2 man) when I can get a buddy to help.
Any help is welcome. Also check out my YouTube channel.
