Hi Gang,
I've been relying on you guys to help me with my Malibu, but now I have a question for a different car. I just bought a 78 Nova to match my 78 Malibu. It's a beautiful, clean car, no rust, small block chevy, but the guy we bought it from said the engine was "blown". When I picked up the car, I asked him what he meant by "blown". He said he thought it was the head gasket. I thought, phew, I was thinking rod through the block. Ok, I want to go simplest things first. The oil is milkshake. I want to drain the oil, look for metal, check the cylinders, change the head gaskets, and try to get the thing running. I know the oil system will need to be flushed. Unless I find out otherwise, I'm going to assume bearings are ok, for now. My question: What order do you recommend I do things? Flush oil first, head gasket first, compression test first? Then what would you do? I've never had to diagnose and fix a problem this major before, so I need all the help I can get. Thanks in advance!
Rob
Rob
