Body trim repair
86Monte.carlo
9
17
Can someone please help me with a suggestion for a nose bottom trim fix? The front bottom side molding is coming unadhered from the fender.
Thanks,
Pete
DROLDS84
464
788
Northern Indiana
Hard to see what I'm looking at with the fuzzy pics but I have used the 2 part body panel epoxy to glue all kinds of things from bumper ends to broken clips and plastic mounted bolts on grills and filler panels with great success.Just make sure the surface is clean and rough up the areas you want to bond with some coarse sandpaper.
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,702
Spring, Texas
It seems like that lower piece must fasten to the fender mechanically?
86MCSS86
47
8
I had a similar issue with mine. For me it turned out that 1 stud was broken. I would check for loose fastener or broken stud. I used two part epoxy to glue a screw with a flat head to the back of it.
